Playlists as Podcast exception
Unread postby troycarpenter » 14 Feb 2017, 19:42
On the Madsonic server (latest 6.2.9240), from the "More" menu on the left, under Podcast. It says:
Saved playlists are available as Podcasts.
Use the following URL in your Podcast receiver: http://yourhostname/podcast, or click here.
When I clicked "here", I got the following error:
Exception   java.lang.NullPointerException
Message   null
Java version   Oracle Corporation 1.8.0_121
Operating system   Linux 4.4.0-62-generic
Server   jetty/8.y.z-SNAPSHOT
Memory   Used 185 of 421 MB
Stack trace   java.lang.NullPointerException
   at org.madsonic.controller.PodcastController.handleRequestInternal(PodcastController.java:69)
troycarpenter
Has thanked: 19 times
Been thanked: 50 times
Re: Playlists as Podcast exception
Unread postby Madevil » 17 Feb 2017, 15:44
please retry with snapshot 6.2.9260
Has thanked: 1339 times
Unread postby troycarpenter » 20 Feb 2017, 00:36
Madevil wrote:please retry with snapshot 6.2.9260
Same error
troycarpenter
Return to Bug Reports 6.x
