WARNING no transcoder found!
Unread postby KaeTuuN » 10 Mar 2017, 11:27
 VERSION:      MADSONIC 6.2 | BUILD: 9040
 SERVLET:      TOMCAT 8
 SERVER:       CPU: Core i3-6100 | ARCH: X64 | MEMORY: 16GB | HDD: 6TB + 3TB | SSD: 128GB |
 OS:           Linux Mint 18.1 including Debian like hardening
 SYSTEM:       SERVER
 INSTALLER:    WAR File
 JAVA:         ORACLE JDK 1.8
 BROWSER:      does not matter
 CLIENT:       does not matter
 DESCRIPTION:  "WARNING no transcoder found!" - Fresh Installation via "WAR-File" and the "/var/madsonic/transcode" Directory doesn't even Exist
 REPRODUCIBLE: YES
So, how do I manually configure a transcoder?
What are the Standard entries?
The "ffmpeg" package from Distri Source is installed.
Mfg Kae
KaeTuuN
Has thanked: 2 times
Re: WARNING no transcoder found!
Unread postby Matt Zornig » 11 Mar 2017, 04:02
maybe you need to put the ffmpeg into the path?
can you reach it on the console, just typing ffmpeg --help in your home-directory?
this is what my settings look like:
check: transcode path
Downsample command
ffmpeg -i %s -map 0:a:0 -b:a %bk -ar 44100 -v 0 -f mp3 -
HTTP Live Streaming command
ffmpeg -ss %o -t %d -i %s -s %wx%h -v 0 -b:v %bk -maxrate %bk -bufsize 256k -flags -global_header -map 0:v:0 -map 0:%k -ac 2 -f mpegts -c:v libx264 -preset superfast -c:a aac -b:a 96k -strict -2 -threads 0 -copyts -
Dynamic Adaptive Streaming command
ffmpeg -ss %o -t %d -i %s -async 1 -b:v %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f webm -c:v vp8 -preset superfast -c:a libmp3lame -threads 0 -
audio->mp3:
ffmpeg -i %s -map 0:a:0 -b:a %bk -v 0 -f mp3 -
Been thanked: 20 times
Unread postby KaeTuuN » 18 Mar 2017, 12:37
Thanks for the help! I had the wrong transcode path...
Changed it and everything is ok. :)
Greetings Kae
KaeTuuN
Unread postby eevv » 24 Mar 2017, 06:21
On one Synology NAS I have Subsonic, installed using the ffmpeg version of Synology Serviio, supposedly. But in the log I can see that it is somehow "access denied" to ffmpeg, so if it's eg a FLAC it will just play the file without transcoding to mp3 or whatever. Which is fine but no good in the long run if playing from mobile with data quota.
Could I conceivably fix this simply by copying and pasting your commands as listed here ?
If that breaks something, is there a specific config file or something to delete to reset transcoding settings to what they were when package installed ? Or would I then also lose the whole database etc. too ?
Matt Zornig wrote:maybe you need to put the ffmpeg into the path?
Downsample command
audio->mp3:
eevv
Been thanked: 6 times
Return to Support 6.x
