Crash after SignUp Registration
Unread postby HarryM61 » 19 Apr 2017, 13:28
After i signed up the formular chrashes with this report ???
I only installed the software as descriped.
What´s wrong - can someone help?
The parameter are :
Version MADSONIC 6.2.9080.2a5cd1f.20161222.0601 - IP address [anonym]
Server jetty/8.y.z-SNAPSHOT, java 1.8.0_121, Linux 4.8.0-34-generic (amd64) (145,2 MB / 277,5 MB)
Size: Database: 289MB, Thumbs-Cache: 3MB, LastFM-Cache: 1MB, Lucene-Cache: 38MB
Transcoder ffmpeg version N-82759-g1f5630a-static http://johnvansickle.com/ffmpeg/ (22.12.2016)
Copyright (c) 2000-2016 the FFmpeg developers
location /var/madsonic/transcode/ffmpeg
And here is the Log from the crash
Exception org.springframework.dao.DataIntegrityViolationException
Message PreparedStatementCallback; SQL [insert into user (username, password, email, ldap_authenticated, bytes_streamed, bytes_downloaded, bytes_uploaded, group_id, locked, comment, approved) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; integrity constraint violation: foreign key no parent; FK_GROUP_ID table: USER; nested exception is java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: foreign key no parent; FK_GROUP_ID table: USER
Java version Oracle Corporation 1.8.0_121
Operating system Linux 4.8.0-34-generic
Memory Used 138 of 302 MB
Stack trace org.springframework.dao.DataIntegrityViolationException: PreparedStatementCallback; SQL [insert into user (username, password, email, ldap_authenticated, bytes_streamed, bytes_downloaded, bytes_uploaded, group_id, locked, comment, approved) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; integrity constraint violation: foreign key no parent; FK_GROUP_ID table: USER; nested exception is java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: foreign key no parent; FK_GROUP_ID table: USER
at org.madsonic.dao.UserDao.createUser(UserDao.java:134)
at org.madsonic.service.SecurityService.cloneUser(SecurityService.java:515)
at org.madsonic.controller.MultiController.signup(MultiController.java:244)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:471)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:408)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:139)
Caused by: java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: foreign key no parent; FK_GROUP_ID table: USER
... 82 more
Caused by: org.hsqldb.HsqlException: integrity constraint violation: foreign key no parent; FK_GROUP_ID table: USER
at org.hsqldb.Constraint.getException(Unknown Source)
at org.hsqldb.Constraint.checkInsert(Unknown Source)
at org.hsqldb.StatementDML.performIntegrityChecks(Unknown Source)
... 87 more
with best regards
Harry M
HarryM61
Re: Crash after SignUp Registration
Unread postby HarryM61 » 21 Apr 2017, 11:44
Hallo MadSonic Gemeinde,
hat keiner eine Idee was da falsch läuft?
VG HaryM61
HarryM61
Return to Support 6.x
Users browsing this forum: Google [Bot] and 1 guest
