/usr/syno/synoman/webman/3rdparty/Madsonic
/volume1/@appstore/Madsonic
/tmp/madsonic
{PUBLIC_FOLDER}/Madsonic/
Madevil wrote:Hi there,
the Madsonic 6.3.9480 Synology installer has improved database handling, new search engine, proxy support, local network interface fix and other bug fixes
viewtopic.php?f=44&t=2229
if you get failed to install Madsonic maybe old Madsonic installation fragments block the installation, so try to cleanup before new installation:
remove any existing Madsonic package via web-interface, connect via ssh daemon and remove those folders if exist
- Code: Select all
/tmp/madsonic
reboot and retry installation with latest DSM installer
2018-05-03T04:04:25+02:00 Server synoscgi_SYNO.Core.Package.Installation_1_install[24003]: pkginstall.cpp:449 Failed to run preinst script for Madsonic, 1
2018-05-03T04:10:15+02:00 Server synouser: user_set.c:139 pUser->szName[madsonic] is EXIST.
