6.3.x FLAC playback issues
Unread postby mplogas » 30 May 2017, 11:12
VERSION: MADSONIC 6.3 | BUILD: 9480
SERVLET: JETTY
SERVER: CPU: XEON E3-1220LV2 | ARCH: X64 | MEMORY: 16GB | HDD: 16TB
OS: FreeNAS 9.10.2 @ FREBSD 9.1
SYSTEM: SERVER
INSTALLER: STANDALONE
JAVA: ORACLE JDK 1.8
FFMPEG: ffmpeg version 3.3 built with FreeBSD clang version 3.4.1
BROWSER: CHROME 58, Edge
CLIENT: DSUB | MADSONIC APP | SonicStreamer
DESCRIPTION: Playback (transcoding) of FLAC files is interrupted
REPRODUCIBLE: YES
When running any 6.3.x snapshot, streamng/conversion of FLAC starts for 20-50s and then stops for ~20s, then continues for a short time (less than 10s) and stops eventually. No log entry in madsoniclog, no logentry in messages, even in Debug level. No CPU spike. Not an network issue, as the traffic coming from the madsonic machine just stops according to the firewall logs.
Switching back to 6.2.x resolves the issue.
mplogas
Has thanked: 1 time
Re: 6.3.x FLAC playback issues
Unread postby Madevil » 30 May 2017, 11:41
try to reset your settings to default if you upgrading from older builds Settings > Reset > Transcoding profil > Madsonic - Default
Has thanked: 1339 times
Unread postby mplogas » 30 May 2017, 19:39
I tried both resetting the Transcoding and resetting (removing) the madsonic.properties. Didn't change anything, unfortunately. I'm back to 6.2 atm (with that dreaded sonderzeichen bug ;) ) but can switch to 6.3 within an hour or so. Let me know if you have an idea how I can log this wierd bug.
mplogas
Has thanked: 1 time
Unread postby Madevil » 30 May 2017, 22:26
This is possible a problem from the underlying audio parsing library which parse the wrong content-length on some media types like FLAC.
you can track this problem if you open your browser console ( CTRL + SHIFT + J ) you will see a net::ERR_CONTENT_LENGTH_MISMATCH
to solve this problem, config: Settings > Admin Panel > Scanmode Metadata -> MIXED
after this make a full mediascan: Settings > Media Tools -> Full Rescan
This will fix the playback stutter! :)
Unread postby mplogas » 31 May 2017, 10:21
Thanks, that did the trick! Back on 6.3, streaming to MadSonic App, SonicStreamer and Browser without any issues (and with special chars in Tags ;) ).
mplogas
Has thanked: 1 time
Unread postby garyo » 07 Jun 2017, 03:41
The CONTENT_LENGTH_MISMATCH error for ogg files is back for me. :-( I'm seeing this in the Chrome console, and the player starts spinning:
GET https://music.xxx.com/stream?player=6&id=10544&auth=123123&scrobble=false net::ERR_CONTENT_LENGTH_MISMATCH
I've updated ffmpeg and done multiple complete rescans. I'm using MIXED scan mode (have been for a long time). Things were fine until one of the recent updates; I'm running the latest 6.3.9500 now. FreeBSD.
Running ffmpeg on the source ogg file, I can see the actual length is 3:23, just the time when the playback stops and spins in the player. The player thinks the song length is 4:12.
If it's any help, when I do a curl of that URL, I get an mp3 file of the proper length (3:23). And more, I see the X-Content-Duration header set to 202.0 seconds (or 3:22), which is at least approximately OK, anyway not 4:12.
garyo
Has thanked: 3 times
Been thanked: 12 times
Unread postby garyo » 07 Jun 2017, 04:08
... and it's not just oggs. It's happening for mp3s too. For instance, Rickie Lee Jones' Show Biz Kids is actually 4 min 35 sec long. In my player, that's where playback hangs... but the player thinks it's 5:44. The main madsonic index page knows it's 4:35.
garyo
Unread postby garyo » 07 Jun 2017, 15:48
Fixed!
Madevil PMed me: after the upgrade, need to do Settings > Reset > Reset Transcoding Profile to default. Then do a full rescan. Now the player knows the correct length and my playback doesn't hang. And no more CONTENT_LENGTH_MISMATCH browser errors.
Thanks as always for the great support, Madevil!
garyo
Unread postby garyo » 12 Apr 2018, 20:36
Unfortunately this ERR_CONTENT_LENGTH_MISMATCH error seems to be back, in 6.3.9840, with some flac files.
I applied the procedure listed above (reset transcoding profile and full rescan), but I still get this error in Chrome occasionally -- a few times per day, and the player stops working. Have to go to next track by hand to reset it.
garyo
Return to Bug Reports 6.x
