Script to run War upgrade in the new Madsonic
Unread postby chali » 21 Sep 2013, 00:03
This script is made by Marty, i have only made a small edit so it will work with the new Madsonic
Remember to run it as root and to use big letters (Y/N) when you answer the questions in the console,
When it asking for the built number it the last 4 numbers ( example 3660)
/Sincerely Chali
madsonicupdate.sh
Masonic War update script
(2.76 KiB) Downloaded 236 times
chali
Has thanked: 89 times
Been thanked: 66 times
Re: Script to run War upgrade in the new Madsonic
Unread postby nodename » 13 Aug 2017, 02:12
Can I use this script to upgrade from 5.x to 6.x? And will the Android client need to be changed as well?
nodename
Unread postby Madevil » 13 Aug 2017, 11:19
This script is only for upgrading the server installation.
We working on a new transfer tool to migrate old data to the new Madsonic 6.3 database.
https://gist.github.com/MadMarty/2ed7f59fce1e6bebe5e78f04e19e4749
Stay tuned! ;)
Has thanked: 1339 times
Unread postby nodename » 15 Aug 2017, 00:02
Yes, I understand it's for the server. That's what the first part of my question referred to.
Can I use the script to upgrade the server from 5.x to 6.x?
What is the implication of your comment about migrating the data? Is upgrading the server with the script not sufficient?
Also is the current release of the Android client compatible with 6.x?
nodename
Return to Info
