failed to load when internet is off
Unread postby sekisushai » 08 Feb 2016, 00:33
I've got an install of madsonic 5.1.5260 working, but i've noticed that the server won't launch when my internet connection is off.
Here is the concerned line of madonic_sh.log :*
févr. 07, 2016 6:24:46 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFOS: Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@753059df: startup date [Sun Feb 07 18:24:46 EST 2016]; root of context hierarchy
févr. 07, 2016 6:24:46 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFOS: Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
févr. 07, 2016 6:24:46 PM org.springframework.util.xml.SimpleSaxErrorHandler warning
AVERTISSEMENT: Ignored XML validation warning
org.xml.sax.SAXParseException; lineNumber: 7; columnNumber: 66; schema_reference.4 : Echec de la lecture du document de schéma 'http://www.springframework.org/schema/beans/spring-beans.xsd' pour les raisons suivantes : 1) Le document est introuvable ; 2) Le document n'a pas pu être lu ; 3) L'élément racine du document n'est pas <xsd:schema>.
As I understand, madsonic is looking for a fine online
spring-beans.xsd
so if I'm offline I cannot start the service..
I'm often running on wifi connection and the latter connects after the that madsonic tried to automatically start, so it fails according to the log above.
I'm running unbuntu 14.04, I tried to install the package libspring-beans-java, but it didn't help..
Any idea how to fix this ?
sekisushai
Been thanked: 5 times
Re: failed to load when internet is off
Unread postby addseo1115 » 22 Jun 2016, 09:30
Very nice, it makes me understand more.
addseo1115
Unread postby RichardGhval » 28 Apr 2017, 17:02
I am haveing that Problem also .... started when i downlaoded the New Internet Explore.............
Havent figured out how to fix it yet
RichardGhval
Unread postby Eddie » 18 Sep 2017, 03:21
I'm running freenas with the latest madsonic plugin and my internet has been out for a few days and infant locally access my music via madsonic... no internet means no madsonic even if I'm local... that s crazy
Eddie
Has thanked: 2 times
Return to Bug Reports 5.x
Users browsing this forum: Baidu [Spider] and 0 guests
