Java exception when adding folders with "Never" as interval
Unread postby Tak-MK » 18 Sep 2017, 09:25
First of all:
 VERSION:      Madsonic 6.3.9560.3e2ad42.20170712.0529
 SERVLET:      Integrated with madsonic, I suppose it's Jetty.
 SERVER:       CPU: i5-3470T | ARCH: X64 | MEMORY: 2GB | HDD: 6TB
 OS:           Debian 9
 SYSTEM:       Server
 INSTALLER:    Deb
 JAVA:         OpenJDK 8
 BROWSER:      Any
 CLIENT:       Madsonic 6.3
 DESCRIPTION:  Java exception when adding folders with "Never" as interval.
 REPRODUCIBLE: Yup
Hi!
As the title says, when you add a media folder and set "Never" as interval, it adds well, but appears an exception. This will not be an issue except from the fact that if you reboot madsonic with a media folder with that "Never", it'll consume 100% of the CPU and never will start. :(
Java Exception:
    java.lang.IllegalArgumentException: Non-positive period.
   at java.util.Timer.schedule(Timer.java:286)
   at org.madsonic.service.MediaScannerService.schedule(MediaScannerService.java:109)
   at org.madsonic.controller.MusicFolderSettingsController.onSubmit(MusicFolderSettingsController.java:128)
   at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:415)
   at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:387)
   at org.springframework.web.servlet.mvc.SimpleFormController.processFormSubmission(SimpleFormController.java:272)
   at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:268)
   at java.lang.Thread.run(Thread.java:748)
Thanks a lot!
Tak-MK
Has thanked: 4 times
Been thanked: 12 times
Re: Java exception when adding folders with "Never" as inter
Unread postby Madevil » 18 Sep 2017, 18:42
Has thanked: 1332 times
Been thanked: 963 times
Unread postby Tak-MK » 19 Sep 2017, 08:46
Madevil wrote:confirmed, will be fixed with next release. :thumbsup:
Perfect, thanks! :D
Tak-MK
Unread postby sparc » 17 Nov 2017, 02:55
This showed up for me in Windows Server 2012 R2 in the form of a hung service at ~50% CPU when the service was started using a domain user account (admin, I have music stored on NAS & full r/w privileges to it). When I would start the service with the LOCAL SYSTEM account, it starts just fine...but I can't access the music folders.. which is probably why it is able to start.
Coincidentally, I did have all my media folders set to Never as the interval. So, I started it using the LOCAL SYSTEM account. Changed all of them to 6 months, saved. Stopped Madsonic, Started Madsonic using the domain user account & voila. It is fixed.
Definitely some kind of an issue with Never as the interval. The madsonic logs in Windows were not very helpful. The last item as it hung at 50% CPU was Initializing Spring root WebApplicationContext.
Thanks OP.
sparc
Has thanked: 7 times
Unread postby Tak-MK » 17 Nov 2017, 11:51
sparc wrote:This showed up for me in Windows Server 2012 R2 in the form of a hung service at ~50% CPU when the service was started using a domain user account (admin, I have music stored on NAS & full r/w privileges to it). When I would start the service with the LOCAL SYSTEM account, it starts just fine...but I can't access the music folders.. which is probably why it is able to start.
Thanks OP.
Exactly. That's what I had to do to raise up properly the madsonic daemon. Glad my post helped other to bypass the bug! :D
Tak-MK
Return to Bug Reports 6.x
