Is Server 6.3.9560 stable enough to use?
Madsonic Server 6.x
Unread postby zzzonedotnet » 21 Sep 2017, 12:19
Anyone using Server 6.3.9560?
Is it stable enough to try and/or use?
Thanks.
zzzonedotnet
Has thanked: 6 times
Been thanked: 10 times
Re: Is Server 6.3.9560 stable enough to use?
Unread postby Tak-MK » 21 Sep 2017, 14:30
Well, it works, but there's a bug at least to be fixed in the next release, be careful if you install the 6.3.9560 --> viewtopic.php?f=63&t=2379
Tak-MK
Has thanked: 4 times
Been thanked: 12 times
Unread postby zzzonedotnet » 15 Oct 2017, 12:41
Thanks for your reply.
What setting would that affect? How could I avoid evoking that bug?
Thanks.
zzzonedotnet
Unread postby Tak-MK » 15 Oct 2017, 15:38
zzzonedotnet wrote:Thanks for your reply.
Thanks.
As I wrote:
As the title says, when you add a media folder and set "Never" as interval, it adds well, but appears an exception. This will not be an issue except from the fact that if you reboot madsonic with a media folder with that "Never", it'll consume 100% of the CPU and never will start.
But there's a new version now, it should be fixed.
Tak-MK
Unread postby KBanause » 05 Jul 2018, 08:17
I'm using version 6.3.9840 right now, and this bug still exists. Even though I don't see any exceptions in the logs, my madsonic doesn't start anymore when it's trying to setup the scan tasks at startup.
KBanause
Has thanked: 1 time
Return to Server 6.x
