LDAP
Madsonic Server 6.x
Re: LDAP
Unread postby albertocastillo2001 » 17 Oct 2017, 14:43
Thank you. I also checked the ldap info page. Seems that the only kind of allowed groups are based on "groupofnames" class. I guess it's not possible to use "posixGroups" right?
Enviado desde mi ONE A2003 mediante Tapatalk
albertocastillo2001
Re: LDAP
Unread postby Madevil » 17 Oct 2017, 16:46
albertocastillo2001 wrote:Thank you. I also checked the ldap info page. Seems that the only kind of allowed groups are based on "groupofnames" class. I guess it's not possible to use "posixGroups" right?
Try to setup your Madsonic Ldap configuration as follow:
LDAP group filter:
(memberUid={1})
LDAP group role attribute:
cn
Tested with OpenLDAP on Ubuntu 17.04 server
LDIF example:
dn: ou=possix,dc=madsonic,dc=org
objectClass: organizationalUnit
objectClass: top
ou: possix
dn: cn=madsonic.admin,ou=groups,dc=madsonic,dc=org
objectClass: posixGroup
objectClass: top
cn: madsonic.admin
gidNumber: 1002
memberUid: bob
dn: cn=madsonic.config,ou=possix,dc=madsonic,dc=org
objectClass: top
cn: madsonic.config
gidNumber: 1001
memberUid: bob
dn: uid=bob,ou=users,dc=madsonic,dc=org
objectClass: posixAccount
objectClass: person
objectClass: organizationalPerson
objectClass: inetOrgPerson
objectClass: top
cn: bob
gidNumber: 500
homeDirectory: /home/users/bob
sn: bob
uid: bob
uidNumber: 1002
userPassword: bob
Has thanked: 1325 times
Been thanked: 963 times
Re: LDAP
Unread postby albertocastillo2001 » 17 Oct 2017, 16:47
That's the way I did with the older stable version. It would never grab the roles. I will try with the latest one available. Thanks!
albertocastillo2001
Re: LDAP
Unread postby albertocastillo2001 » 13 Dec 2017, 23:36
Hi!
I am really sorry I couldn't answer before. but had to halt this project for a while.
I came back to it today and attempted to setup LDAP using posixGroups.
I had to reinstall Madsonic snapshot due to the license key no longer being valid. However, using the trial it seems to work well using posixGroups, auth is done properly with the correct user level depending on the group the user is added.
albertocastillo2001
Previous
Return to Server 6.x
