6.3.9840.8df1ddd.20180107.0710 license issue
fetchinson
Post by fetchinson »
I believe I have a valid license with the email address fetchinson@googlemail.com and if I check it at
https://www.madsonic.org/backend/licenseStatus.view
I indeed get a confirmation of a valid license (see attachment). Nevertheless when I enter the email address and license key in
Settings > Madsonic Premium
I get "Invalid Madsonic license key!"
My madsonic version is 6.3.9840.8df1ddd.20180107.0710
Any ideas what's going on?
These users thanked the author fetchinson for the post:
Re: 6.3.9840.8df1ddd.20180107.0710 license issue
Post by Madsonic »
Technically, your license works in our test center.
It is more likely a connecting problem to our license server.
Do you use a proxy server? There may be a problem with your firewall rules or the router.
katubun
Post by katubun »
Same situation here,
My license was valid until June 2019. I Check it on https://beta.madsonic.org/backend/licenseStatus.view and it was ok until June. I update my license for another year and the situation is still the same. The server is Full Capable of accesing the net. (May be the license server down?)
I'm running Freenas 11.2 and MADSONIC 6.1.8700.3847bea.20160915.0741
katubun
Post by katubun »
Any Advance? Received by anyone?
KaeTuuN
Has thanked: 5 times
Been thanked: 18 times
Post by KaeTuuN »
Have you tried to run a newer Version of Madsonic, since 6.1 seems to be out of support?
You should migrate at least to 6.2 or join the 7.0 Beta which runs nice, except of a HTTPS Bug.
Greetings Kae
katubun
Post by katubun »
ok I will try it, Thank You
Post by Madsonic »
katubun wrote: 01 May 2019, 18:41 Same situation here,
Madsonic 6.1 is very outdated, but we have build a patch release.
Send you a PM with download link to test if it's working again.
katubun
Post by katubun »
Upgraded by manually putting MADSONIC 6.2.9084.8df1ddd.20190425.1020 files. Server works but the license issue is still in the same situation.
Post by Madsonic »
katubun wrote: 10 May 2019, 17:04 Upgraded by manually putting MADSONIC 6.2.9084.8df1ddd.20190425.1020 files. Server works but the license issue is still in the same situation.
Can you please provide more information, error messages or debug log-file to help!
Check also here: viewtopic.php?f=75&t=2649#p8355
