[Script] Script to rescan MediaFolders
Posted: 10 Dec 2012, 04:41
some People want to trigger this more often as you can set in Madsonic.
i write a short windows script to trigger this action.
:: Rescan Madsonic ::
:: rescan Subsonic MediaFolders
set username=admin
set password=admin
set serverlink=http://127.0.0.1
wget %wgetsettings% --load-cookies=%temp%\cookie.txt --referer="%serverlink%" "%serverlink%/musicFolderSettings.view?scanNow"
