Madsonic 5.1 FreeNAS Plugin
INFO
TESTED
- FreeNAS 9.2.1.7
SOURCE
https://github.com/MadMarty/FreeNAS-Plugins
DOWNLOAD
http://madsonic.org/download/FreeNAS/ma ... -amd64.pbi
Hi there,raidflex wrote:I am unable to start the plugin. I setup a plugins jail and installed the PBI but it refuses to start. I am running Freenas 9.2.1.7, please advise.
Also the link on this post to download the PBI is for Synology not Freenas.
The only difference I had was I did not change the permissions for the jail Dataset, but even after changing the permission the plugin will still not start. I also had a similar problem with Tech Demo III when I overwrote the Subsonic plugin jar/war files. If I overwrote the jar/war files with TD II's then the plugin would start without issue, not sure if this is related.Madevil wrote:Hi there,raidflex wrote:I am unable to start the plugin. I setup a plugins jail and installed the PBI but it refuses to start. I am running Freenas 9.2.1.7, please advise.
Thanks, update download link!
maybe you forgot some requirements, please follow and recheck this steps
- new FreeNAS 9.2.1.7 installation
- create new ZFS Volume -> example: Storage
- create new ZFS Dataset -> example: public for media
- create new ZFS Dataset -> example: pluginjails
- edit ZFS Dataset Security -> check write for group other
- configure Jails path to the new created dataset pluginjails
- install Madsonic package
- configure plugin
- start plugin
- done!
Yeah I suspect its a permissions issue also, but after looking through everything it seems correct. I am using ZFS.jayd wrote:Same here. I believe the issue is related to permissions. I'm on UFS *eh my media server only has 4 gig ram*.
Have you updated to Freenas 9.2.1.8 and then reinstalled the plugin? This is what fixed the same problem for me.darthanubis wrote:What if these steps are already done, because the luxury to a fresh install of Freenas one does not have?
I have tried to create a jail
give it the correct permissions
add storage to the jail
install the plugin
configure the plugin
start the plugin
Yet the plugin fails repeatedly without an error that I can tell.
Is a fresh install mandatory? Or is there a way to plugin this plugin in to a running system
