Remove SSLv2 and SSLv3 from valid cipher suites
HasiPopasi
Unread post by HasiPopasi »
Hi all,
in the light of the latest developments about the security of SSL encryption it would be time to remove the insecure cipher algorithms SSLv2Hello and SSLv3 from the list of valid cipher suites. Madsonic provides them as in the log file statet :
oejus.SslContextFactory:Enabled Protocols [SSLv2Hello, SSLv3, TLSv1, TLSv1.1, TLSv1.2] of [SSLv2Hello, SSLv3, TLSv1, TLSv1.1, TLSv1.2]
Question : How do I disable SSLv2Hello and SSLv3? I can't find a setting for this and Madsonic seems to use an embedded version of Jetty without any possibility to change this server setting for the user.
These users thanked the author HasiPopasi for the post:
DoCC
Has thanked: 40 times
Been thanked: 65 times
Re: Remove SSLv2 and SSLv3 from valid cipher suites
Unread post by DoCC »
the smoothest way to use your own selected ssl features ,
try running madsonic on localhost with nonssl
and setup a apache proxy server with ssl support.
this will do the trick very well. and you can create you own certs : )
ootuoyetahi
Unread post by ootuoyetahi »
HasiPopasi wrote:Hi all,
Were you ever able to figure out how to disable sslv3?
i'll change your security suggestion :thumbsup:
            if (isHttpsEnabled()) {
                SslSocketConnector sslConnector = new SslSocketConnector();
                SslContextFactory sslContextFactory = sslConnector.getSslContextFactory();
                sslContextFactory.setExcludeCipherSuites(
                        new String[] {
                            "SSL_RSA_WITH_DES_CBC_SHA",
                            "SSL_DHE_RSA_WITH_DES_CBC_SHA",
                            "SSL_DHE_DSS_WITH_DES_CBC_SHA",
                            "SSL_RSA_EXPORT_WITH_RC4_40_MD5",
                            "SSL_RSA_EXPORT_WITH_DES40_CBC_SHA",
                            "SSL_DHE_RSA_EXPORT_WITH_DES40_CBC_SHA",
                            "SSL_DHE_DSS_EXPORT_WITH_DES40_CBC_SHA"
                sslContextFactory.addExcludeProtocols(new String[]{"SSLv3","SSLv2Hello"});
result:
2015-05-06 09:46:07.497:INFO:oejus.SslContextFactory:Enabled Protocols [TLSv1, TLSv1.1, TLSv1.2] of [SSLv2Hello, SSLv3, TLSv1, TLSv1.1, TLSv1.2]
https://github.com/MadMarty/madsonic-se ... 58f339a755
