API access broken [solved]
Mission accomplished!
DoCC
Has thanked: 40 times
Been thanked: 65 times
Unread post by DoCC »
regarding to
http://www.subsonic.org/pages/api.jsp
AND
http://beta.madsonic.org/api.jsp
It is not possible to get any info form either my own server or the demo server of MadEvil ...
I'd just wanted to get some now playing info and parse them via php.
as it says getNowPlaying.view doesn't require any additional parameters.
but there are always these error msgs
<subsonic-response xmlns="http://madsonic.org/restapi" status="failed" type="madsonic" version="1.12.0">
<error code="10" message="Required parameter is missing."/>
</subsonic-response>
whats on there ?
DoCC
Re: API access broken
was broken in 5300
is still broken in 5420
just easy like 1-2-3 :)
look at the API Introduction for required parameter http://beta.madsonic.org/api.jsp
in your case for http://beta.madsonic.org/api.jsp#getNowPlaying
try this:
http://localhost:4040/rest/getNowPlaying.view?u=admin&p=admin&v=1.12.0&c=php
result
<subsonic-response xmlns="http://madsonic.org/restapi" status="ok" type="madsonic" version="1.12.0">
<nowPlaying>
<entry id="13343" parent="13326" title="Little Bad Girl" album="Nothing But The Beat - Disk2" artist="David Guetta" isDir="false" coverArt="13326" year="2011" genre="House" created="2013-02-07T00:49:30" duration="243" bitRate="320" track="4" size="9763522" rank="0" suffix="mp3" contentType="audio/mpeg" isVideo="false" path="David Guetta/[2011] Nothing But The Beat/Disk2/04 David Guetta - Little Bad Girl.mp3" artistId="854" type="music" username="Marty" playerId="1" minutesAgo="0"/>
<entry id="2716" parent="2715" title="City Of Ocala" album="Common Courtesy" artist="A Day To Remember" isDir="false" coverArt="2715" year="2013" genre="Rock" created="2013-10-08T11:43:20" duration="209" bitRate="320" track="1" size="8687038" rank="13" suffix="mp3" contentType="audio/mpeg" isVideo="false" path="A Day To Remember/[2013] Common Courtesy/01 A Day To Remember - City Of Ocala.mp3" albumId="63" artistId="110" type="music" username="guest" playerId="10" minutesAgo="0"/>
</nowPlaying>
DoCC
DoCC
: ) merci
Then you should fix the API section
It clearly states : " no parameters needed "
getNowPlaying
http://your-server/rest/getNowPlaying.view
Since 1.0.0
Returns what is currently being played by all users. Takes no extra parameters.
Returns a <subsonic-response> element with a nested <nowPlaying> element on success.
In addition looks like your example files are broken : )
Re: API access broken [solved]
no extra parameters
was referring to additionally required paramter like in this example:
http://localhost:4040/rest/getTopTrackS ... ele&size=5
Yes, the whole page is in beta phase, many parts are missing or disabled :?
for API development this schema will be helpful
https://github.com/MadMarty/madsonic-se ... st-api.xsd
DoCC
harr i hob was neichs zum spuin
eeerm new stuff to mess around with jihaa xD
DoCC
a little bit of parsing, a little bit of headache with fucking css but all seems fine now
2 Examples on the fly
Next step would be ... pipe this stuff into an png graph.
mmh jo ^^
EDIT: I found a way to pipe the entire page into an dedicated "onetime-image" for the browser.
If this step works , i could think of an mysql based backend, allowing multiple users from multiple servers creating ther own images.
With custom text and maybe with custom value-fiels out of the box ...
I guess this would be a nice job burning some braincells ^^
EDIT II:
- step 1 is taken
image decprecated
EDIT III:
- step 2 is taken
i am now able to set different styles, maybe i will adapt all madsonic styles present.
at the moment there is an "tron" like and a basic orange "old school" style.
as this is the very basis i am now thinking of an mysql backend.
things stored ( encrypted ) in this db will be stuff like
- hostname
- port ( if different from 80 )
- admin login credentials ( full API access )
- username to be parsed
- desired style
if this part is done and all stuff runs as expected, i think about setting up a registration page so that users can change their values if needed to.
Hell yeah x-mess time is coming, nothing better to do then ^^
DoCC
Another step is done.
The backend is now based on mysql .
This allows to completely design the pic on the fly out of the db.
I have added pictureIDs instead of usernames.
just have an first impression :
id=GsdET3 .. this is the madsonic test account
id=initial .. my own : )
i will look forward to the next crazy stuff ^^
DoCC
Please feel free for beta testing : http://madsonic.power-server.at
