[solved] 5420 Database >Pandora > Navigation crashed.
Posted: 27 Dec 2014, 14:47
hellaz,
i had to reboot my server due to security updates. The reboot was triggered by script.
I think the forced shutdown -r may have caused some trouble with the bloody database.
As we all know the hsql DB runs completly in the RAM. It might by that the RAM wasn't able to put his info back to the madsonic.script file.
Due to that :
Ergo DB fucked up . time to reinitialize . jihaaaa ....
to be honest, this sucks. 1,1 TB takes its time ...
i apreciate the day if there comes an oracle db around the corner : P
EDIT ::
After reinitialize, copying my credentials, trancoder settings, podcasts etc pp
the debug log looks fine again ...
conclusion ...
If you have a large amount of files . and a huge madsonic db.
you need an UPC ( apc, liebert or whatever ) and a BIG BIG reminder on your desktop to shut down the madsonic FIRST and then your host
Due to that :
[27.12.14 14:24] INFO DaoHelper Checking database schema.
[27.12.14 14:24] INFO Schema47 Database table 'media_file' not found. Creating it.
[27.12.14 14:24] ERROR DaoHelper Failed to initialize database.
[27.12.14 14:24] INFO DaoHelper Checking HSQLDB version: 2.3.2
[27.12.14 14:24] DEBUG VersionService Resolved local Madsonic version to: 5.2.5420
EDIT ::
[27.12.14 14:54] INFO DaoHelper Checking database schema.
[27.12.14 14:54] INFO DaoHelper Done checking database schema.
[27.12.14 14:54] INFO DaoHelper Checking HSQLDB version: 2.3.2
[27.12.14 14:54] DEBUG VersionService Resolved local Madsonic version to: 5.2.5420
[27.12.14 14:54] INFO UserService Checking User accounts ...
[27.12.14 14:54] DEBUG SecurityService ## Updated user default
[27.12.14 14:54] DEBUG SecurityService ## Updated user guest
[27.12.14 14:54] INFO UserService Checking Default User. Done
[27.12.14 14:54] DEBUG SecurityService ## Updated user demo
[27.12.14 14:54] INFO UserService Checking Demo User. Done
[27.12.14 14:54] INFO MediaScannerService Automatic library scan: every 1 day(s), NEXT: Sun Dec 28 03:00:00 CET 2014
[27.12.14 14:54] INFO UPnPService Checking UPnP service...
[27.12.14 14:54] INFO UPnPService Disabling UPnP/DLNA media server
[27.12.14 14:54] INFO UPnPService Checking UPnP service - Done!
[27.12.14 14:54] INFO PodcastService Automatic Podcast scan: every 1 hour(s), NEXT: Sat Dec 27 14:59:42 CET 2014
[27.12.14 14:54] DEBUG JaudiotaggerParser ## GenreMap turned OFF
[27.12.14 14:54] INFO NetworkService Deleted port mapping for port 4040
