[solved] browse folders option removed?
Posted: 17 Jan 2015, 17:49
by sIRwa2
Usually the location shown in the screenshot is where you can choose your different shared folders. but since i upgraded (new install new server) i cant, for the love of god, find an option in the settings menu where to re-enable that. is it been taken out? if so, why?
2d problem is that my chrome browser (Win7 & OSX) is not offering to remember the server password, and checking the "remember me" box does not function either. is this a bug?
im on ehhh.. where can i find the version? this fork is starting to have too many menu's and options
madsonic-5.2.5420 on Debian wheezy
Re: browse folders option removed?
Posted: 18 Jan 2015, 21:43
by DoCC
chrome remembers the credentials, user and pw. you have to hit login by your self.
IF your client of the browser it self was restarted !
if you close madsonic tab and open it again the login is done automated.
but as long these session cookies are host only i can not tell if they are working . i connect via proxy pass.
the location for quickjump is now at the bottom of the page
Posted: 19 Jan 2015, 07:26
by sIRwa2
Tnx for the reply, I restarted my machine, that seem to help the login issue, strangely enough.
About the Folders, in the screenshot: where its says "All Music" I used to be able to find/select the different folders that holds my music. now all music folders seem to be treated as one single folder. Is there an option that will treat folders the "old" way wher you had the option to view your music per folder or view all.
Posted: 19 Jan 2015, 13:03
by DoCC
i dont have seen this option in the last 2 builds.
Posted: 22 Jan 2015, 09:26
by lain
I have this exact same problem! I made a thread about it as well but it seems to be removed?
I sincerely hope we can bring it back. Is there any way to petition for it?
EDIT:
Oh! I found the fix.
In the groups tab under Media Folders, Select "Don't group"
Posted: 24 Jan 2015, 09:57
by sIRwa2
Wauw! tnx for finding that.. seems obvious now..
