[Solved] SSL Keystore
Mission accomplished!
TastyJams
Been thanked: 22 times
Post by TastyJams »
I had my own signed SSL certificate running with build 5260. When upgrading to 7450, I transferred my subsonic.keystore (renamed as madsonic.keystore) into the new madsonic-booter.jar. Upon running I am not able to connect. SSL works fine with the default SSL key but I don't want to use that. What am I doing wrong?
These users thanked the author TastyJams for the post:
Re: SSL Keystore
Post by Madsonic »
The only difference is that since Madsonic 6 the alias and password for the keystore is madsonic.
How to create a new keystore:
keytool -genkey -v -keystore madsonic.keystore -alias madsonic -storepass madsonic -keyalg RSA -validity 100000 -dname "CN=madsonic.org, O=Madsonic"
keytool -list -v -keystore madsonic.keystore -storepass madsonic
This should do the trick :D
BTW: if you don't want to edit your booter file each time, you can add this arguments
  -Dmadsonic.ssl.keystore=/var/tmp/my.keystore
  -Dmadsonic.ssl.password=mypassword
TastyJams
Re: [Solved] SSL Keystore
Post by TastyJams »
Thank you! Worked perfectly.
apastuszak
Post by apastuszak »
Where on Linux do I add these arguments?
