I stopped the madsonic service and re-named all of my previous madsonic installation directories and installed the deb package for ubuntu. Apparently Jetty is pissed for some reason and I get the following when trying to access my server.
HTTP ERROR: 503
Problem accessing /. Reason:
Service Unavailable
Powered by Jetty://
I tried stopping the madsonic service and deleting /var/madsonic/jetty/7520 folder and restarting the server, but no dice. I also install Oracle Java 8 and set it as my default java on the server. I'm not sure what to try now. I've had Jetty errors in the past, but normally letting the DB rebuild itself fixes the issue. Suggestions appreciated.
[Solved] Erro 503 after 6.x install.......
Re: Erro 503 after 6.x install.......
Fixed it! I think it was Java version related. I deleted the installation and re-installed. I'm think I didn't set the new Java as the default before the previous installation and it was still trying to use an old verison.
