I am not able to play AppleLossless files in Masonic 6.x.
I tried resetting any possible Transcoding profile, but when I play an AppleLossless file (mac), the player (new or old) hangs.
AppleLossless play fine in Subsonic 5.2 & 5.3.
Thanks in advance!
Emanuele
AppleLossless
Re: AppleLossless
I wanted to add more data:
I believe Transcoding together with the new player is the issue. By disabling transcoding for audio, every format now plays fine.
When Transcoding is enabled the player doesn't start playing until the full file has been transcoded. For example an aac may take 20 / 30 seconds before it plays on my mac.
They will play fine without transcoding or using external or jukebox player.
Any suggestion for the new player?
Emanuele
Emanuele
