Network error occurred / timeout Madsonic 6.0 Server 6.3
Mr.Burns
Post by Mr.Burns »
Hey,
I'm new to Madsonic and have first setup a 6.2 server, which i removed completely and now setup version 6.3.
I had some problemes (albums are empty by using android client) so i switched to the beta version.
I'm currently using dsub and the new madsonic app on Android.
Dsub is fine for now but if I'm using the madsonic app it's not possible to open / sync large playlists. (~2000 songs)
I've already increased the timeout limit to 60 seconds but the problem is still there.
Furthermore there is now entry in the logfile, level is set to debug. Is this normal?
I've tested connecting by IP and fqdn.
Error Message: Network error occurred. Retrying 1 of 4
Playback from library etc is working with both apps, just the playlist issue.
Madsonic Android 6.0.0
Madsonic Server 6.3.9720
Any ideas / help ? :)
