Is it possible to use a 4.6 install to seed madsonic, or do I need to start over from scratch?
Right now I get a schema issue from missing columns in my tables.
java.sql.SQLException: Column not found: ALBUM_ARTIST
thanks!
-m
this FAQ Articel can guide you: http://forum.madsonic.org/viewtopic.php?f=5&t=31Thanks, I figured that would be the case. Is there any way to just get the user table over? I have way too many users to go and do password resets.Madevil wrote:hi,
since 4.8 the upgrade should work, but i sounds like a rare migration issue.
i recommend you to start from scratch, you have clean index, new default Setting-File, new Transcoding defaults ...
-m
