[Script] Create User Accounts within Madsonic
Scripts for Madsonic
i wrote a short windows script to create User Accounts within Madsonic.
NEW: Set Default Security GroupID & new Role searchRole
REST API 1.9.2 needed (Madsonic 5.0)
:: Create Madsonic Acount ::
:: Create Madsonic Useraccounts
set username=admin
set password=admin
set serverlink=http://127.0.0.1:4040
.\bin\wget %wgetsettings% --user-agent=Mozilla "%serverlink%/login.view?user=%username%&password=%password%"
:: Create Backup Admin
.\bin\wget %wgetsettings% --load-cookies=%temp%\cookie.txt --referer="%serverlink%" "%serverlink%/rest/createUser.view?u=%username%&p=%password
%&v=1.9.2&c=remoteregister&username=sysop&password=sysop1$&email=sysop@home.com&adminRole=true&settingsRole=true&streamRole=true&jukeboxRole=true&downloadRole=true
&uploadRole=true&playlistRole=true&coverartRole=true&commentRole=true&podcastRole=true&shareRole=true&coverArtRole=true&commentRole=true&searchRole=true&groupId=0"
:: Create Guest
%&v=1.9.2&c=remoteregister&username=guest&password=guest2$&email=guest@home.com&settingsRole=true&streamRole=true&settingsRole=false&jukeboxRole=false&downloadRole
=false&uploadRole=false&playlistRole=false&coverartRole=false&commentRole=false&podcastRole=false&shareRole=false&searchRole=false&groupId=1"
:: Create Friend
%&v=1.9.2&c=remoteregister&username=friend&password=friend3$&email=friend@home.com&settingsRole=true&streamRole=true&jukeboxRole=false&downloadRole=true&uploadRole
=true&playlistRole=true&coverartRole=false&commentRole=false&podcastRole=false&shareRole=false&commentRole=true&searchRole=true&groupId=3"
CreateUser.zip
(1.71 MiB) Downloaded 660 times
Has thanked: 11 times
Been thanked: 105 times
Re: [Script] Create User Accounts within Madsonic
Unread post by gurutech »
I've added the following to the script, so it will prompt you for a username, password (which will NOT be hidden), email address, and access level.
To implement, add the following to the beginning of the script, just after the section where you add your "admin" ID and password and the server URL:
set /p user= "Username: "
set /p userpw= "Password: "
set /p useremail= "E-Mail: "
echo 0 = FULL ACCESS
echo 1 = GUEST
echo 2 = FAMILY
echo 3 = FRIENDS
echo 4 = LIMITED
echo.
set /p accesslevel= "Enter # for Access Level: "
Then add the following line at the END of the script. Comment out the three existing lines (samples) to create a new admin, guest, and friend.
.\bin\wget %wgetsettings% --load-cookies=%temp%\cookie.txt --referer="%serverlink%" "%serverlink%/rest/createUser.view?u=%username%&p=%password%&v=1.9.2&c=remoteregister&username=%user%&password=%userpw%$&email=%useremail%&settingsRole=true&streamRole=true&jukeboxRole=false&downloadRole=false&uploadRole=false&playlistRole=true&coverartRole=false&commentRole=false&podcastRole=false&shareRole=true&commentRole=true&searchRole=true&groupId=%accesslevel%" >nul
I'm working on adding capability to set permissions on individual components (Jukebox, streaming, download, upload, etc...) through being prompted. Will reply again with that update.
e1z0
Unread post by e1z0 »
Creating user accounts using php as easy as shell scripts for example for external php registration. So here is the code:
// ADMINISTRATOR ACCOUNT INFO
$ADMIN = 'admin';
$PASS = 'verylongpassword';
$HOST = 'http://127.0.0.1:4040'; # we not use external URL for security reasons
// USER PERMISSIONS
$STREAMING='true';
$JUKEBOX='false';
$DOWNLOAD='false';
$UPLOAD='false';
$PLAYLIST='true';
$COVERART='false';
$COMMENT='false';
$PODCAST='false';
$SHARE='false';
$COMMENT='true';
$SEARCH='true';
$GROUPID='3';
// function to register user to Madsonic database using external API's
function madsonic_regiser($username,$password,$email) {
    global $ADMIN, $PASS, $HOST, $STREAMING, $JUKEBOX, $DOWNLOAD, $UPLOAD, $PLAYLIST, $COVERART, $COMMENT, $PODCAST, $SHARE, $COMMENT, $SEARCH, $GROUPID, $INVITE;
QUERY = $HOST."/rest/createUser.view?u=".$ADMIN."&p=".$PASS."&v=1.9.2&c=remoteregister&username=".$username."&password=".$password."&email=".$email."&settingsRole=true&streamRole=".$STREAMING."&jukeboxRole=".$JUKEBOX."&downloadRole=".$DOWNLOAD."&uploadRole=".$UPLOAD."&playlistRole=".$PLAYLIST."&coverartRole=".$COVERART."&commentRole=".$COMMENT."&podcastRole=".$PODCAST."&shareRole=".$SHARE."&commentRole=".$COMMENT."&searchRole=".$SEARCH."&groupId=".$GROUPID;
$ch = curl_init($QUERY);
curl_setopt($ch, CURLOPT_HEADER, 0);
curl_setopt($ch, CURLOPT_POST, 0);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
$output = curl_exec($ch);
curl_close($ch);
Cheers!  :)
These users thanked the author e1z0 for the post:
