Android Client 5.4
Posted: 18 Jul 2013, 22:52
Android Client 5.4
Amazon App Store Link
Release Note
General
- BS Videoplayer support
- VLC Videoplayer support
- Dialog: add song to new created Playlist
- small Bugfixes
Re: Android Client 5.4
Posted: 19 Jul 2013, 00:54
Posted: 23 Jul 2013, 18:21
by chali
Hello and thank you for all your work =)
in this vertion has blitvit problems to stream,
movie starts not until the entire film is transferred;
Now, I have not had time to test if it's the app or if it is the server vertionen that is the problem for me. (I use beta4 3560 Debian)
does anyone have an idea what could be the problem?
last vertionen worked perfeckt for me with mx player.
and vertionen 3550 Debian)
/ Sincerely Chali
Posted: 23 Jul 2013, 19:20
chali wrote:Hello and thank you for all your work =)
/ Sincerely Chali
whats is a
blitvit ???
Maybe the newer
ffmpeg version have problems with some video transcodings,
did you try the last or older ffmpeg version?
Posted: 24 Jul 2013, 13:25
by chali
Madevil wrote:chali wrote:Hello and thank you for all your work =)
/ Sincerely Chali
whats is a
blitvit ???
Maybe the newer
excuse me, I'm using Google translate and the word (blivit) means
(has become) in Swedish.
I have not tested any other ffmpeg (I do not know how to do it)
I only use your debian or war updates (to war, I use your scripts)
Well this is not a huge problem for me, I can always wait and test the next update
/ Sincerely Chali
Posted: 29 Sep 2013, 02:09
by chali
I have a problem.
anyone using sony xperia go, can no longer stream movie from me (if they not use flash) (or sometimes it goes if you wait very long >5 min)
I have tested bs, vlc, and mx without further results.
I have tested different arm5, 6.7, for mx and neo
someone who has a smart idea?
/ Sincerely Chali
Posted: 29 Sep 2013, 06:08
by gurutech
Just downloaded this version, after sticking with 5.0 since that came out. Reason for the upgrade was because I keep getting "server cannot be found" error messages, and a timeout after 4 attempts.
I figured it was due to the server itself, being upgraded from 35xx up to 3700, which was just released. Since Ultrasonic was giving the same error, I didn't think it was an app issue, however I thought maybe the server was responding to the connection request in a new
Well, the upgrade didn't fix the problem.
Any idea what could be causing this issue?
Posted: 29 Sep 2013, 21:35
by chali
gurutech wrote:Just downloaded this version, after sticking with 5.0 since that came out. Reason for the upgrade was because I keep getting "server cannot be found" error messages, and a timeout after 4 attempts.
hi
i got this error when the hdd spin down and i tried to stream a few hour later.
after fixing the spin down, the error is gone, hmm i also got this when using vdsl2 but no longer after getting fiber
/Chali
Posted: 29 Sep 2013, 23:17
by gurutech
very strange.... I plug in my actual IP address, with port 4040, and it works.
Not sure why the domain name I'm using isn't working, but I'm gonna have to look into that.... Everything seems to be working fine when I go over a browser....
Posted: 29 Sep 2013, 23:53
by chali
gurutech wrote:very strange.... I plug in my actual IP address, with port 4040, and it works.
hi
are you using dyndns?
test to sett the TTL to 60 and Type to A
but i still think it can be that the hard drive spin down, or do you get this error every time you connect using the app?
or is it that you first time out and on the next attempt you can connect?
/Chali
Posted: 30 Sep 2013, 00:21
by gurutech
It's all the time, but only when using my DNS name. Using No-IP.com on a port 80 redirect (to get around my ISP blocking port 80).
Works fine if I use my external IP address and put in port 4040.
Works fine using IP address or DNS name from a browser.
Posted: 30 Sep 2013, 10:48
by chali
gurutech wrote:It's all the time, but only when using my DNS name. Using No-IP.com on a port 80 redirect (to get around my ISP blocking port 80).
hmm starting to get low on ides
you enter the address
http://youradress.your /
https://youradress.your not youradress.your ?
and what happens if you putt in
http://youradress.your:4040?
/Chali
Posted: 03 Oct 2013, 22:09
by chali
Little more hassles
android app, choose English instead of Swedish, although that Swedish is No. 1 in the order of the soundtrack
both in flash and mx-player, is probably because it is not possible to choose Swedish in the app =)
you can add a marker to (se) (Swedish)
you can not turn the subtitle of on several things in android using mx player (presumably the mx player who is wrong.)
/ Sincerely Chali
Posted: 07 Oct 2013, 23:57
by chali
Bs player givs this error.
Have only tryde it in flash mode since html5 dont work for me the last builts.
/Chali
Re: Android Client 5.4 and note 3
Posted: 20 Oct 2013, 18:32
by chali
More Trouble
using galaxy note 3 and android 4.3
mx player lags like crazy using HW codec, and HW+ only work on some files, and only after the whole file is downloaded (take minimum 10 minutes to start playing using HW+)
software codec don't work at all, and flash (using mobile firefox) dont work any more.
if am using serviio to send the file to Mx player it no problem using HW and HW+ so maybe it a problem how madsonic give Mx player the file?
one + side is that subtitle work
im regretting not sticking to note 2
sincerely/Chali
Posted: 22 Oct 2013, 01:13
by commonplace
I can't seem to get the Madsonic app to send Bluetooth information to my car's stereo. It works on Google Play Music and others, but not Madsonic... am I doing something wrong, or is this not supported??
Posted: 22 Oct 2013, 18:56
by chali
commonplace wrote:I can't seem to get the Madsonic app to send Bluetooth information to my car's stereo. It works on Google Play Music and others, but not Madsonic... am I doing something wrong, or is this not supported??
it don't work for me neither.
/Chali
Posted: 28 Oct 2013, 01:26
by ramapoughnative
Greetings.. Minor issue. I'm using android app 5.4 and even though it's paid for, still getting commercial splashscreen on pause.. why? BTW.. thank you for writing and sharing this app..
truly enjoy it..
Posted: 29 Oct 2013, 19:10
by chali
ramapoughnative wrote:Greetings.. Minor issue. I'm using android app 5.4 and even though it's paid for, still getting commercial splashscreen on pause.. why? BTW.. thank you for writing and sharing this app..
truly enjoy it..
Though it is not madsonic wrong, I presume you are using MX player?
Have you paid for it? Probably not,
advertising comes from mx player that is Standalone from madsonic,
Want to remove ads, buy mx-player. or use flash
/ Chali
