Madsonic installed: no share visible
jannuh
Unread post by jannuh »
Installed Madsonic this evening, was a subsonic user till Spring 2012.
Everything seems okay, put mediafolder on the right place and start scanning, but no shared files are visible.
The logfile mentioned....
[22-10-13 23:40] INFO MediaScannerService Scanned media library with 82500 entries.
[22-10-13 23:40] INFO MediaScannerService Scanned media library with 83000 entries.
[22-10-13 23:40] INFO MediaScannerService Scanned media library with 83310 entries.
[22-10-13 23:40] INFO MediaScannerService Marking non-present files.
[22-10-13 23:40] INFO MediaScannerService Marking non-present artists.
[22-10-13 23:40] INFO MediaScannerService Marking non-present albums.
[22-10-13 23:40] INFO MediaScannerService Completed media library scan.
[22-10-13 23:40] INFO PlaylistService Starting playlist import.
[22-10-13 23:40] INFO PlaylistService Completed playlist import.
[22-10-13 23:40] INFO PlaylistService Starting playlist statistics update.
[22-10-13 23:40] INFO PlaylistService Completed playlist statistics update.
What could have gone wrong???
jannuh
Installed Madsonic this evening, all went fine.
Filled in map to share and started scanning, seemed to go okay, but afterwards
no shared files were visible. Did rescanning again, still no files visible.
Any idea?
Edit: posted before, but wasn't visible in forum, maybe needed validation as first post??
Anyhow forget this one...
Re: Madsonic installed: no share visible
I suspect one of the last library updates caused this.
i will check and fix this with next build!
jannuh
Is it I true in that build 3770 doesn't fix the problem I raised??
I rescanned, but still no music.
I de-install and re-install again later for test...
addseo1115
Unread post by addseo1115 »
