http://forum.madsonic.org/viewtopic.php ... t=20#p2423
As I am working on the completion of my comment.txt-files I get more and more problems with madsonic to handle them.
The reason seems to be character handling and coding.
As I create this comment.txt-files partly by copy & paste from websites i obviously get unsuitable charcters and coding for madsonic. But I am far away from understanding and recognizing all the reasons for the problems.
If I tell madsonic to make a rescan I can see in the log where madsonic stopped to scan obviously because of an unwanted character in the file.
If I switch to that sepcial folder with madsonic it is not able to show the comment but gives this error message:[20.12.13 10:44] INFO MediaFileService ## CommentFile found: e:\music ....\comment.txt
[20.12.13 10:44] ERROR MediaScannerService Failed to scan media library.
Error
Exception java.lang.NullPointerException
Message null
Java version Oracle Corporation 1.7.0_45
Operating system Windows 8 6.2
Server jetty/8.y.z-SNAPSHOT
Memory Used 223 of 621 MB
Stack trace java.lang.NullPointerException
at net.sourceforge.subsonic.service.MediaFileService.checkForCommentFile(MediaFileService.java:1088)
at net.sourceforge.subsonic.service.MediaFileService.createMediaFile(MediaFileService.java:629)
at net.sourceforge.subsonic.service.MediaFileService.checkLastModified(MediaFileService.java:183)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:298)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:273)
at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:113)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:667)
Whatare the requirements for the comment.txt-files anyway?
