The project clearly isn't dead.
There's a changelog posted every two weeks or so.
It looks like it's coming along well.
As for anyone who wants to test it, there's a download link on the main download page: http://beta.madsonic.org/pages/downloadBeta.jsp
Madsonic 6.0 Sneak Peak
- Has thanked: 1 time
- Been thanked: 3 times
- Developer
- Been thanked: 8 times
Re: Madsonic 6.0 Sneak Peak
Hi Scott,daneren2005 wrote:What is it that you changed that requires changes from clients?
This changes should fix Madsonic REST 2.0.0 and Subsonic REST 5.3 support
AbstractParser.java
protected String getElementName() {
String name = parser.getName();
if ("subsonic-response".equals(name) || "madsonic-response".equals(name)) {
rootElementFound = true;
String version = get("version");
if (version != null) {
ServerInfo server = new ServerInfo();
server.setRestVersion(new Version(version));
if ("madsonic-response".equals(name)) {
server.setRestType(ServerInfo.TYPE_MADSONIC);
if ("1.10.5".equals(version)) {
if("madsonic".equals(get("type"))) {
server.saveServerInfo(context, instance);
return name;
if (server.isStockSubsonic()) {
builder.append("&v=").append(Constants.REST_PROTOCOL_VERSION_SUBSONIC);
} else {
builder.append("&v=").append(Constants.REST_PROTOCOL_VERSION_MADSONIC);
builder.append("&c=").append(Constants.REST_CLIENT_ID);
return builder.toString();
public static final String REST_PROTOCOL_VERSION_SUBSONIC = "1.2.0";
public static final String REST_PROTOCOL_VERSION_MADSONIC = "2.0.0";
RESTMusicService.java
some slightly name corrections for this API names http://beta.madsonic.org/pages/api.jsp#top
getArtistInfo, getArtistInfoID3,
getSimilarSongs, getSimilarSongsID3,
getSimilarArtists, getSimilarArtistsID3,
search, searchID3,
getStarred, getStarredID3,
getAlbumList, getAlbumListID3
you can also use the new logon methods with Madsonic --> http://beta.madsonic.org/pages/api.jsp#Authentication
Hope this help you.
Martin
- Developer
Yes that does help a lot thank you! I will make sure that DSub supports the new madsonic.
btw,
Technical Madsonic supports all Subsonic REST API 1.13 calls,
and should be compatibility to all your new implemented features.
Bookmarks, Artistinfo, load/save PlayQueue, ...
Martin
Martin
- Developer
How exactly are you calculating that the salt/token is valid? Using the exact same code which works against a stock Subsonic server it fails saying wrong username/password.
