troubleshoot install
kurtm83
Post by kurtm83 »
i thought i had everything installed correctly on my raspberry pi, but when i try to go to the madsonic webpage it says unable to connect. firefox cant establish a connection to the server. any ideas where i went wrong?
frank2228
Has thanked: 32 times
Been thanked: 11 times
Re: troubleshoot install
Post by frank2228 »
Do you have any more info? Screenshot of the error message perhaps?
How are you trying to connect to the server? Are you loading it in a web browser on the raspberry pi itself, are you trying to load it on a different computer in your network, or are you trying to access it from outside your LAN?
What OS are you running on the pi and what Madsonic server version are you using? Was the Madsonic installed over an old installation?
Is the Madsonic service running?
