Madsonic Docker support
First try, to dockerize Madsonic
Here you can find some helpful links:
https://docs.docker.com/userguide/
Madsonic repos
https://hub.docker.com/u/madsonic
UnRAID templates
https://github.com/MadMarty/docker-templates
used images
https://registry.hub.docker.com/_/alpine/
https://registry.hub.docker.com/_/debian/
https://registry.hub.docker.com/_/ubuntu/
https://registry.hub.docker.com/u/phusion/baseimage/
https://registry.hub.docker.com/u/madsonic/arch-base/
Madsonic docker container
https://registry.hub.docker.com/u/madsonic/arch-madsonic
https://registry.hub.docker.com/u/madsonic/debian-madsonic
https://registry.hub.docker.com/u/madsonic/ubuntu-madsonic
https://registry.hub.docker.com/u/madsonic/phusion-madsonic
https://registry.hub.docker.com/u/madsonic/alpine-madsonic
happy testing
Re: Madsonic Docker support
first of all thanks for the Docker image, it was real easy and simple to set it up on my synology NAS.
i actually for the first time was able to stream video to isub using this latest image but i also noticed that the url of the streams are exposed and anyone can actually stream any file by guessing the stream ID and without login.
is this something on my setup or some permission not being set correctly on madsonic side? it seems the madsonic admin account is being used for the stream
thanks
thanks
just a little update.
it seems like this is true on any setup and server version and has nothing to do with synology or docker. this happens even on madsonic/subsonic demo site.
one of the reason i noticed this was the extreme number of hits/played on one of my video series on my server over 1500 in matter of days and i only have like 10 user with 3-5 of them being active users!
with the new Madsonic 6.1 branch, authentication stream endpoint with token will solve this issue.
http://beta.madsonic.org/pages/changelog.jsp#6.1
This is a real good news! and the 6.1 version already looks promising and slick. it seems like we are moving away from flash.
Hi and thanks for working on the Docker support. I had a question regarding the docker images for Unraid. Why are there 4 different ones? And why would I choose one vs another? Just trying to figure out which one I should use. Im currently on Unraid 6.1.9.
Thank you,
Adrian
Thank you,
Adrian
I currently using one of my docker image for Madsonic, it's based on Alpine.
Advantage is the weight of the image (around 5Mb for alpine).
Complete size (on serveur is 231Mb) and the actual tag on the hub a around 150Mb.
I think proposing an image based on Alpine can be great
Link of my image on the hub : arckosfr/madsonic (can't post URL)
Have a good day !
Have a good day !
Thanks for the great docker images!
Any chance of getting an update to the madsonic/arch-madsonic branch docker similar to the ubuntu and debian based dockers?
br
br
Hey. I was trying to use containers and thought id give this a try. I have a test openmediavault 3.0 VM that I am trying out and just installed their stable docker plugin. I found the madsonic debian image and started it, and a container showed up. But the container keeps "restarting" over and over.
I don't know if its something I did, or if its the image itself, or what. Any ideas?
mkdir: cannot create directory ‘/config/media’: Permission denied
mkdir: cannot create directory ‘/config/playlists’: Permission denied
mkdir: cannot create directory ‘/config/transcode’: Permission denied
cp: cannot stat ‘/var/madsonic/transcode/linux/*’: No such file or directory
/var/madsonic/madsonic.sh: 164: /var/madsonic/madsonic.sh: cannot create /config/madsonic_sh.log: Permission denied
Started Madsonic [PID , /config/madsonic_sh.log]
I'm using a standard Debian Madsonic Image installed in ContainerStation (Docker) on my QNAP TS-453Mini server, and it runs just beautifully.
With the new versions coming out for download, any possibility for an update to the docker images in the near future?
I am still using “madsonic/debian-madsonic” (which has been running smoothly for 2 years), but would be great to try the new version 7 out as a docker install (running in Unraid).
I am looking into building an unRaid server (maybe TrueNAS ?) and I would like to know if there are plans to update the official docker on hub.docker.com ?
I see several old files (3 years old or more) and all on beta.
It would be nice to have access to more recent releases and also stable releases.
I did find a github with 7.0 beta but I would prefer something officially or at least semi-officially maintained directly from the site or the forum.
