Statistics -Audiobooks
madsub
Been thanked: 19 times
Unread post by madsub »
I had a look at my statistics recently and noticed there are listed 0 Audiobooks.
As I have some audiobooks (MP3s) in my library - what do I have to do to get them listed as audiobooks?
DoCC
Has thanked: 40 times
Been thanked: 65 times
Re: Statistics -Audiobooks
Unread post by DoCC »
i got only one audiobook ...
and this is a file named " die bombe die nicht tickt (audiobook) "
there are no special info in metaheads or mp3 tags ...
i guess the only chance to flag an audiobook, is to rename it like this
Has thanked: 11 times
Been thanked: 105 times
Unread post by gurutech »
Put the audiobook files into a separate sub-folder outside your main music folder, and add it as a second media folder in Madsonic.
I did this between Music, Movies, and Audiobooks.
madsub
gurutech wrote:Put the audiobook files into a separate sub-folder outside your main music folder, and add it as a second media folder in Madsonic.
My audiobooks are in a seperate folder and they don't show up as audiobooks in the statistics.
for clarification: the identification for audiobooks are
if (path.contains("audiobook") || genre.contains("audiobook") || path.contains("audio book") || genre.contains("audio book")) {
    return AUDIOBOOK;
daneren2005
Developer
Developer
Been thanked: 8 times
Unread post by daneren2005 »
Mad you may want to make that a case insensitive check. A lot of people like title case ;)
Sent from my Nexus 5 using Tapatalk
daneren2005 wrote:Mad you may want to make that a case insensitive check. A lot of people like title case ;)
Thanks, thats a good idea!
madsub
Madevil wrote:for clarification: the identification for audiobooks are
All my audiobooks have "Audiobook" in the genre-tag.
In the meantime I had a look at the integrated database-features and made a database-query "SELECT TOP 500 * FROM media_file where TYPE='AUDIOBOOK'".
The audiobooks are listed there.
But the statistics still says that iI have 0 audiobooks.
The statistic also says that I have 1 podcast with 7 MB in my MP3-Album-Folders. I never cared about podcasts in my life and I don't know what this could be.
These users thanked the author madsub for the post:
