Import multiple playlists and postcast-files at once
I read in this forum that playlists are stored internally and not in the 'playlist' folder. Now changing from subsonic to madsonic, I have lot of playlists to import. However, the interface of madsonic allows to import only one per time. Is there a folder which would be scanned on server start for not-yet imported playlists, or any other way to add multiple playlists at once? Same problem appears with already downloaded potcast-episodes. (I run madsonic 20130725_madsonic-5.0.3572.beta4XE-standalone on a MAC).
Re: Import multiple playlists and postcast-files at once
Ok, a view things are diffrent at madsonic and I didn't see the most obvious solution in the section 'Settings -> Cleanup/Tools'. So the playlist issue is solved by now. However, there seems to be a buggy behaviour concerning search strings with combined characters for which a shall rise another thread.
If you put new Playlists in your Playlist Import Folder on the next Media-Scan all Playlist will be automatically imported.
![Image](http://i.imgur.com/Tc9LFKIl.png)
